Hi !!
I just would like to know how I could calculate/see the final size of my project in Tmpgenc before the encoding
Indeed, If i choose the assistant, I can see it .... but I cannot change any parameters
If i choose manual method, I can change all parameters ... but I cannot see the finale size![]()
Who can help me ??
SeeU
JulienB
There is a tool in the Tools Section called a bitrate calculator which will give you the final size.
"Art is making something out of nothing and selling it." - Frank Zappa -
I've got Tmpgenc 2.511.51.160 (!) and I cannot see this tool
I continue to search for ...JulienB -
The Tools Section of this website, on the left hand column, over there <-<-<-
Honest mistake
In the end thou file size is determined by bitrate and source runtime. The resolution, size of the source, motion search setting, etc. have ZERO effect on file size.
File size = bitrate (kbit/s) * runtime (sec)
That's the total size in kbit (divide by 8 to get size in kb). If you are using the VCD template then 1min = 10MB. As you can burn 800MB (in theory) to an 80min CDR that works out to... 80min!
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
2 pass encoding / Wrong final size
By stanfield in forum Newbie / General discussionsReplies: 26Last Post: 9th Dec 2010, 08:22 -
Help in Final Cut Pro video size
By Sue Barker in forum MacReplies: 8Last Post: 25th Aug 2009, 09:51 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 10:40 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30
